I would like to show you my Supra
I bought it July 2009
the car was saved from a junkyard since it had a bearing problem, no brakes and no clutch :nono:
some photos at the begining of my fight with the car
geting the car back on the road wasn't easy since there aren't popular in Poland and getting parts is difficult :/ after 4 months i finally could ride my baby :biggrinbo: but after about a month a cylinder gasket died
since my mechanic started to strip the engine i took some parts for refurb
after that i had 2 months of fun
after that my turbo died on a highway
i had to get another turbo
when it was done i took it on a dyno :icon_mrgr
200,9 HP / 5532 RPM
153,7 WHP / 5476 RPM
273,7 Nm / 4412RPM
I hoped that it will show more but still the car didn't run for 7 years so it wasn't so bad
next you now snow came xD so I had a loot of fun
since i had some extra $$ i ordered a custom 3" straight exhaust
now the car sounds awesome :naughty: after some time the engine started to make problems :/ when I took it apart I found a burnd piston and damaged cylinder heat :/ so I had to look for a new engine :cry: in march 2010 i swapped the engine (it was after a rebuild) and bought a new clutch
after 2 weak's a i had a massive oli leak :cry: again a bearing died so I had to start it all over again :cry: time pasted and the engine was taken apart. the "rebuild" that it was made before I bought it was made by a moron :/ I didn't had a gasket on the intake manifold, oilpan (instead there was some glue/silicone used when you put the windscrean on :squint: ) and the oil sump for the turbo was covered with same sh*it :: angry ::
at the moment I'm changing the intake manifold for a 2jz style one (hand made
) I hanged the IC for a big aftermarket one
and repaired all of the rubbish that the moron made :/
some pics
with a Nissan Pulsar GTI-R
new rims (for a jeep grand Cherokee)
at the movie making
you cen see it hear -> http://www.supramania.com/forums/showthread.php?131176-My-Supra-Video-)&p=1626425#post1626425
engine reanimation :?
fitting the 4-piston brembo brakes (just checking
making a new air intake in the bumper
and the relocated battery
200,9 HP / 5532 RPM
273,7 Nm / 4412RPM
some pics
at the movie making
