7M-GE Specifications
Supracentral
10
7M-GE SPECIFICATIONS
ENGINE
Valve Clearance (engine cold), mm (in.):
Intake 0.15 - 0.25 (0.006 - 0.010)
Exhaust 0.20 - 0.30 (0.008 - 0.012)
Spark Plug Type:
NIPPONDENSO PQ16R
NGK BCPR5EP11
Spark Plug Gap, mm (in.):
1.1 (0.043)
Drivebelt Deflection with 98 N (10 kgf, 22 lb.) thumb pressure (used belt), mm (in.):
1 15.0 - 17.0 ( 0.59 - 0.67)
2 10.5 - 12.0 ( 0.41 - 0.47)
3 9.0 - 11.0 ( 0.35 - 0.43)
Ignition Timing
10° BTDC (with terminals E1-TE1 of check connector connected.
ENGINE LUBRICATION
Oil Capacity, L (qt., Imp qt.):
Dry Fill 5.1 ( 5.4, 4.5 )
Drain and Refill
With Filter 4.4 ( 4.7, 3.9 )
Without Filter 4.1 ( 4.3, 3.6 )
Oil Grade (API):
SG or better. (If it is impossible to get SG or better grade, you may use SF grade)
Recommended Oil Viscosity (SAE):
Temperature range expected before next oil change.
COOLING SYSTEM
Total Capacity, L (qt. Imp qt):
8.1 ( 8.6, 7.1 )
Coolant Type:
With Ethylene Glycol antifreeze or anticorrosive (Toyota "Radiator Conditioner" anticorrosive or equivalent)
Do not user alcohol type antifreeze.
