5spd swap
dirtlord420
just here
Aug 1, 2005
371
tn
i just got my swap in the mail. whats the link with the info? also theres a plug on the clutch pedal does my auto have that plug if so where is it?
Dirgle
Conjurer of Boost
Pauma Valley, CA
I have two switches on my clutch pedal the lower one is for the neutral safety and the upper one is for the cruse control kill.
Dirgle
Conjurer of Boost
Pauma Valley, CA
It should have them but I'm not positive on that.
The cruise control switch is very handy if you like cruise control. It keeps the engine from over-revving if you depress the clutch to shift while in cruise control. It's nice to have if you’re coming up on somebody you want to pass. You don't have to shut the cruise control off before you down shift. You just push the pedal in and go. If you don't have that switch and you forget to shut cruse control off the engine will just rev up and bounce off the rev limiter until you shut it off, not allowing shifting properly.
The neutral safety switch is up to you. I don't have mine plugged in because I have a remote start.
However both are optional, the car won't scream at you if you don't plug them in. It's up to you, however I highly recommend at least the cruise control switch.
thevork
ShoarmaTeam Member
Hi,
Do you have any information about HOW to hook up the clutch cruise control switch?
I have it on my pedal but where can i connect it?
Can't really find a plug to put it in?
Does the AT harness have a place for it or do we have to splice something together?
