5spd swap questions!
92Turbo
hondas suck
Apr 19, 2005
185
NJ
You will need the slave, crossmember. wing mounts,fly wheel bolts, chutch fork with bolts, and the 2j parts will most likely not work. I just bought all the parts for my swap which I hope to put in this week.
supra90turbo
shaeff is FTMFW!
MA, 01440
If all of the 5spd parts came out of a 1JZ, then the clutch will not work. You will need a 7MGTE clutch.
You can buy it all and sell what you don't need. Someone will probably buy the clutch, but you can definitely get rid of the bellhousing fairly easily.
