550 installation questions
suprafanatic
1,607
Greenwood, IN
im getting ready to install a set of 550s and was just wondering what would be the quickest or easiest way to go about doing it. or anything improtant i need to konw in doing so. thanks!
8,882
What do you mean by the easiest? Your concern should be the proper way. Crimped, and fill the crimp with minmal solder. Toyota explicitly says to do it that way.
And then heat shrink.
suprafanatic
1,607
Greenwood, IN
there are only 2 wires per injector though..?? so it doesnt matter which wires get connected as long as the two injectors wires are connected to the two clip wires for that injector? and do i have to use a clip for that? or can the wires just be soldered together?
suprafanatic
1,607
Greenwood, IN
ok i got the injectors seated in the fuel rail, and i have it bolted back on to the engine...i tightened the bolts as tight as i could and i noticed the injectors will slightly twist side to side, but not back and forth... is this a problem?
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
RTFM = read the f$%* manual. He's not being sarcastic, but it really helps to read the manual. It will tell you how much torque should be used and if the injectors should move etc...
