50 trim ct26
brs86supra
395
suffolk,va.
i was wondering if a 50 trim ct26 is good for making reliable hp, how much hp would i expect to get from one adn how much should i pay for one with a fresh rebuild, with 0 miles on it.
MKIIINA
Destroyer of Turbos
Plano, TX
a 50 trim isnt worth it imho. its such a small step up from the stock wheel youd just be better off getting a rebuild and be done with it or going with a 57 trim whell. check out mdc as mentioned above
bigaaron
4,692
Pomona, CA
www.driftmotion.com
60-1 is too big for a ct26 housing if you want reliability. 57 trim seems to be the best for power and longevity. You can make around 375whp max with a 50 trim, and the spool is pretty fast. 57 trim spools almost the same and can make around 400whp, maybe a little more. All the threads from a while back about people blowing up their ct26 were all 60-1 iirc.
kylefoto
I am not ASIAN!
May 7, 2006
1,674
Lynnwood, WA
Had my 60-1 for about 4 months I want to say and I haven't had any problems with it.
Then again it has a t-4 center housing, not sure how much that would affect anything?
In my own opinon, if it's done right and done by a good company, and you take care of it, there's no reason it shouldn't last long.
Anything to add or correct me on Aaron?
brs86supra
395
suffolk,va.
bigaaron you wouldnt happen to have any spare ones just lying around by any chance would you cause i really need a new turbo mine is shot
