450whp guys
supra88gr
110
s dub
how reliable are your cars? i know it plays a big part on the tune and etc but over all how long will a 7m last at that power?
Your question is going to be hard to answer, but I will tell you a well built 7m will hold 450rwhp for along time with proper maintenance and upkeep. Not too many people on here have the know how to build them properly though. I chose to go with a well built 1.5jz because I'm one of those people that doesn't posess the knowledge that it takes.
How would you put a time frame on something like this?
supra88gr
110
s dub
i have been looking and been around this forum for some time now but i just decided to become a member. i had this place in ct called "the shop" build my car the motor is a jdm "low mileaged" engine that is all stock except a metal head gasket and arp's. the car just made 440whp at 1.2bar. i was just trying to get an idea of how long it will last me. i also know that allot of people make allot more power with there stock 7m's like the guy on this forum that made 700+.
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
Depending on the quality setup you're throwing that power at, it could be imminent failure. Mine is WAY more reliable at this horsepower than it ever was stock.
supra88gr
110
s dub
custom header, custom 4in down pipe, 4in exhaust ,gt35r ,tail 44mm external wastegate, tail bov,custom intercooler pipes with hks intercooler, rc 720cc injectors, welbro pump,AEM ems,hks dli etc
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
I make about 350-390rwhp at 15-17 psi on the street, and am always doing full-throttle acceleration pulls, being a very spirited driver. It's been very reliable so far, owned the car for 2 years.
supra88gr;1156424 said:
custom header, custom 4in down pipe, 4in exhaust ,gt35r ,Tial 44mm external wastegate, Tial bov,custom intercooler pipes with hks intercooler, rc 720cc injectors, walbro pump,AEM ems,hks dli etc
That sounds like a good setup for sure. I had basically the same setup on my 1jz and made 443rwhp @ 17.5psi for over a year and a half with no problems at all. I took the 1jz out in favor of a 2jz block. The verdict is still out on whether or not I made a wise decission.
I didn't correct your spelling to be a prick. I just wanted to make sure you knew the correct spelling for future posts.
drbowser3
The Doc is in...
Jan 17, 2006
215
Tampa,FL
My 89' made about 460-480 on a daily basis at 17psi. I always drove my car hard. My motor had 160k miles on it, all that was done was a MHG and ARP studs.
My setup was near identical to yours. 35r, AEM, Custom Piping, eBay manifold, tial gate and bov, 550s.
@21psi my car made 501, in the heat of florida and after 9 consecutive pulls.
As far as how reliable, I drove the car daily for over a year and a half and it would still be running strong had it not been wrecked.
MKIIINA
Destroyer of Turbos
Plano, TX
the biggest thing is the tune. that will determine how long it will last. why did you go with the 720cc injectors? other than that looks like a decent setup, watch for detonation and it should last a while
mdr40z
arkansas
MKIIINA;1156682 said:
the biggest thing is the tune. ........... watch for detonation and it should last a while
It's the key, I went with slightly lower compression than stock, a little more lag but it never detonates and I'm 1.5 bar consistently on pump gas
Bigdough666
Picture Me Rollin
Apr 4, 2005
367
Corpus Christi, TX
WOW, didnt know about the car. I was reading your post and asked "why is he talking in past tense" then I got to the end. Sorry to hear about your car, that was a nice ride.
To the thread starter, my car should make ~400RWHP. I drove it for about 2 years as a daily with no problems (exceot for traction, hehe). Just make sure you have aftermarket gauges and keep an eye on everything. Maintenance is the key.
supra88gr
110
s dub
i went with 720's cause i figured that if the motor brakes on me then its rebuilt time and bigger turbo :biglaugh: and everything als will support that
MRSUPRA
838
Maryland
A stock internalled 7M with a metal headgasket will be fine at 450rwhp. I ran mine at low 400's for years and high 400's at the track.
The questin isn't the 7M, it's the question of your particular 7M's condition and tune.
Supra469
495
Maryland
As you all speak of 'tuning' let me ask this...
My 7M-GTE had the headgasket replaced-metal, ARPs. I have CT-26 with 57trim, KN, DDP-R, Hard Pipes, High-Flow Cat, Tanabe Cat back.
Do I need a tune?? Or should I?
Are you running lexus afm with 550's? Do you have a wideband hooked up so you can see your afr's?
Supra469
495
Maryland
No. Stock injectors and no wideband. All the mods I have are listed. I'm still trying to understand this whole concept of tuning etc. Thanks.
