450+hp in a 7m?
b005t3d
505
bellevue,nashville, tn
anyone have any ideas as to what would have to be done or added to a 7m-gte to get it around or over 450 hp? just wondering cuz im sitting around 340 rwhp right now and i want to get it to that magical 450 number. then i can finally start on the rest of the car. eithrway, anyone got any ligitimate ideas on parts and where to get them, holla back atchya boy.
boost
siman
Lifetime Ban
Murfreesboro, TN
There is a plethera of information in the tech section sticky...and the general faq's forum.
Explore those tools at your will...they have every single bit of info to make 400+whp.
And its quite easy, counting on the condition of your motor.....new rebuild or 150K mile putter on a stock head gasket...LOL
-Jonathan
b005t3d
505
-Jonathan
im on a balanced motor with about 45k on it. but cool, ill def check that out
MRSUPRA
838
Maryland
Just getting a turbo like the bolt-on SP61GT along with supporting mods will get you there. All you need is the simple bolt-ons that enhance flow, and the fuel system that can support that horsepower. Along with a fuel tuning device and a boost controller.
b005t3d
505
thats what i thought it would take. for a motor thats already turboed i didnt think it would take much. i was more asking if anyone had any good ideas for specific parts but i think ill stick with old faithful.... Greddy :naughty:
b005t3d
505
IHI-RHC7 said:
What turbo do you have right now?
right now, i have the stock ct-26 just with an aftermarket manual boost controller at 11 psi. 550cc inj., arp head studs, centerforce stage 3 clutch, rebuilt tranny, balanced lower end, trd lsd, and custom intercooler piping. unfortunatelly, i still have the stock intercooler so i guess its really not custom then huh? haha
MRSUPRA
838
Maryland
BIC downpipe
Tanabe exhaust
test pipe
RC 550cc fuel injectors
Walbro fuel pump
Lexus AFM
K@N intake
Alamo intercooler and hardpipes
Gredy type R bov
SX fuel pressure regulator
SP61GT turbo
Apex AFC
Apex AVCR boost controller
Cheap boost gauge
Apex EGT gauge
Fuel pressure gauge
Spec 2 clutch
2mm greddy headgasket and ARP head bolts
1 hour dyno tuning
Hows that? That got me 451rwhp at 20.5 psi, with some ignition problems.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Sounds like you need:
- Better fuel pump
- Better fuel pressure regulator
- Aftermarket IC
- A slightly better turbo - 57 trim CT would do it, the SP series will work as well, but that will be overkill.
- A bunch of tuning.
b005t3d
505
- Better fuel pump
- Aftermarket IC
theres a bunch of shit that i didnt mention but everything should be good to run a lot of power. im kinda wondering what intake sensor to use.
