???? 4 Plugs????
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
Were do these 4 plugs go nere the end of the wiring harness???:dunno:
Thay wern't on the NA harness????
Satan
Tampa
Those are the connectors for the dash connections, behind the glovebox (right near the ECU). They are mostly to complete circuits (body connections), but the very small one is for the guages...tach, temp, etc.
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
Then why wern't they on the NA harness:icon_conf
Satan
Tampa
I know that the 7MGTE has quite a few more sensors/connections than the N/A.... If you have the dash harness for a turbo, then it will have the corresponding connectors. I have my dash off again and can take pics if ya want, but given the swapping I've done with the turbo model, I know them plugs pretty well.
I don't have an N/A to look at and compare.
Look at Rick's site for layout of different turbo plugs and what's connected within 'em... http://www.1jz-gte.us/
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
Ya e-mail the pics to me at daledoe5000@yahoo.com
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
they should be on the N/A harness. If not, I'd like to know how the N/A car would even start. they contain wiring that goes to the engine that are out of the realm of the ECU like the start wire, back up light wiring, heater control valve wiring, also things like tach signal to the dash, speed signal to ECU, ECT..... Now the turbo harnesses will usually have more wiring do to things like ABS, PPS, boost signal for boost gauge, Tems and others that are more common to turbo cars.
mcpcola
7M's = Peoples Champ
Jul 4, 2005
428
Greater Gulf Coast
here are the pics the wiring harness on the ground came from a manual and the pics in the car are automatic. Both harness have them and both cars are NA
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
I'll have to look later!!! I pulled the old motor like 5 months ago and I didn't remember unplug 6 pluge????? But what your saying makes cents.
