4" inlet question
selfinfliction
434
ky
i looked around for a bit but couldn't find alot of info..
if i was to get that driftmotion 60-1 t4 w/4" inlet, what needs to be done to make this work? i don't think you would be able to go from a filter to lex maf to inlet because of the huge diameter difference between the 4" pipe and the le maf. so i'm pretty much lost.. is the maf moved to another location or something?
thanks
selfinfliction
434
ky
ok, so it just needs to be hooked up to a reducer? i was thinking it would choke the intake down too much, going from 4" to whatever diameter the lex maf was
