4.30 Differential in a 1jz swapped mk3??
Bobbyt5408
64
NEPA
Well my question is driveability, im gonna be driving the car alot, mainly highway at about 65 70 mph.... what kinda of cruzing RPM will i see with the 4.30 lsd in my 1jz R154 swap? Im currently pussing between 400 and 450 wheel if that makes much of a difference. Now im not sure what ratio is in the car now and i would check but there is still 4" of snow on the ground and i dont feel like messing with it.... So im hoping someone on here has experience with the 4.30 diff in a similar setup or any setup for that matter..
Thanks in advance!
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
I have a W58 with a 4.3 and its not a highway cruiser... Made a 2 hour trip last weekend and the speed limit was 75-80 and i was sitting at around 3600-3700 RPM for about an hour and a half strait :p
sweaver
70
ny
buddy has 4.30s and is at 3000rpm at 55mph in a stock NA.
auto trans
.030
r154 .753
w58 .783
Add that .03 with .2 difference from the diff and you have 2 completely different shifting cars.
T56 can be had with either a .5 or .65 in 6th gear which is why you can cruise at or below 2k at 80 in 6th gear.
supra1008
1,179
Philadelphia
In my red car, I had 1jz r154 and a 4.3 open. I would drive to DC and back to Philly and would do 80-90 the whole way. rpm would be around 3200-3400. since it is .5L smaller then I would still get decent mpg. If you want good hwy mpg then get the 3.7. If you want good track times, stay with the 4.3 if its an lsd. If you want in between go with the 3.8/3.9.
Bobbyt5408
64
NEPA
WOW! this was great, that chart was awesome! Great information! I think i might go with the 4.30 if the price is right until i find the 3.73 cause its not a 100% Drag car and its not a 100% street car its gonna be used in both worlds, but mostly on the road so i guess the 4.30 doesnt make much sense but this open diff SUCKS! and i dont think i can take it any longer! If anyone knows of some one with a LSD in the 3.73 range please PM me im currently in the market!!!
te72
Classifieds Moderator
6,622
9
WHYoming
Dimman;1681193 said:
Could you just do this: (4.30/3.73) X current cruise rpm = new cruise rpm ? (or sub in 3.90 for 3.73 if that's your current rear end)
Never thought about the math that way, but at 75mph, my car (3.73, stock-ish height tires) cruises at about 2850. According to your proposed math, you'd be turning around 3285 rpm with the 4.30 diff. Seems about right... Then again, my Mk2 (w58, 4.30, stock height tires) cruises at about 3700 at ~75mph. Definitely a different trans, a buddy of mine compared the R154 to a 4-speed with an overdrive gear, while the W58 seemed like a 5 speed without overdrive to him.
mensrea
211
Schofield Barracks, HI
I could barely get 5psi with 4.30 in first gear.
To each his own I guess..
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
3.73 is little high for my taste, at least for around town.. if you do a lot of highway miles, it may be just right though.
3.91 is a great compromise IMO.. that combo turns ~3k at 75mph.
makaveli913
1jz and lovin it
Nov 20, 2007
135
Pueblo Co
I have 4.3 in my car and one things for sure its FUN! Highway over here speed limit is 75. Im at about 3200 rpm to 3400 rpm. kinda high but i like it. I removed ps and ac and i get positive boost at 1700 rpms so it burns through the gears quick.
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
I have the 4.30 LSD and it sucks! Gas mileage sucks and trying to hook at the track or anywhere else for that fact, is useless! Im currently looking for the 3.73 LSD to swap and get rid of my 4.30. If you are making any kind of power, you will probably want to ditch the 4.30. It was put in the NA for a reason...it has no power.
Bobbyt5408
64
NEPA
Thats all very helpful information!!! And i should also add im on 18" veil side rims with 255's.... so maybe that would help... if i was under 3k at cruzing speed i could deal with it... @ 2543arvin what kind of tires are you running at the track and what suspension? could that be why your not hooking well cause i hear from others that they do much better with the 4.30 at the track?
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
Im running street tires with Megan coilovers, so not Im not set up for the track but I can tell you that you will run through ALL 5 gears in the 1/4 mile, and that sucks!
