Brutus;1089380 said:I need your help not to fry my 7M ECU when I get it.
This is the pinout of the ECU: http://www.geocities.com/MotorCity/Pit/9975/enginepix/drawings/ToyTCCS_Pins_7M-GE_87.gif
Assuming the few things I know about Toyota ECUs:
-Analog sensors (AFM, TPS, ITS, WTS) voltage should be between 0 and 5V
-Except O2 sensor which must be somewhere between 0.3V and 1.2V
-Except Knock sensor (not really analog), whose voltage output is unknown to me.
What about igniter signals, Test socket input, RPM sensor, Speed sensor, stop light switch?
Which ones are 0-5V and which ones are 12V?
The factory EWD is very detailed, as is the repair manual. One note, Toyota doesn't employ a typical 5 volt refrence on the ECT sensor. It compares voltage needed to overcome ther NTC resitor to a 5 volt refrence. I would have to get the book out to see what else though.
AFM is Hz, knock sensor is Hz, engine speed and position is analog pick up. I know JJ will assist as soon as he sees this.
