350HP with stock ct26?
boostedma70
Missoula MT
Ok so the latest I have been hearing is you can get 350hp with lexus afm, fuel pressure regulator, intercooler,yada yada, with stock ecu and stock ct26. You run 14 psi through the turbo and up your fuel pressure 10 static lbs everything runs right and reliable......anyone heard this before or have any thoughts on this would it work, maybe, or I'm just plain out hearing junk.
Enraged
A HG job took HOW long??
21
Victoria, BC, Canada
don't know about that combo, but the stock ct is capable of it. my car did 320rwhp, just need a new clutch and a shimmed wastegate actuator to up the boost.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
I don't know about 14 lbs + stock CT26 = reliable. I've heard of too many CT26s having bad things happen at those boost levels.
For sure though, make sure that you have a very good blowoff or bypass valve, because any compressor surge at all is going to shorten the life of that turbo considerably.
radiod
1,342
Abbotsford, BC
It might have been included with the "yada yada", but just wanted to make sure. Add fuel pump and 550cc injectors. Also is a good idea to get a wideband to see where you're running at and probably something to make some fuel adjustments with (SAFC or equivelant)
Turbo Habanero
4,229
Tucson,AZ
350whp? or BHP?
Cause i personally don't see much more then 300WHP on a stock CT-26 and i wouldn't push the stock turbo more then 12psi to 13psi
tomsupra8683
82gts7mgte
Mar 31, 2007
105
puyallup
its possible to hit 350hp im near it just need to be dyno tuned.ive got high comp pistons,na cams,divorced down pipe,large front mount intercooler,560cc injectors and the lexus maf,2.5 inch intercooler piping,my boost runs between 12-15lbs on the stock wastegate no aftermarket boost controller or shims.Ive also got safc ready too install.
Turbo Habanero
4,229
Tucson,AZ
That's how your making the extra power.
But other then that i have the same mods as you (not ddp or n/a cams) I've never been on a dyno but i would say AT MOST i'm at 280whp @ 12psi
NA cams don't add power. Honestly, if anything, they lower power as it chokes the top end where the turbo kicks in. Why do you think Toyota changed the cam (only intake) in the first place?
While it's possible to do, you're on the ragged edge of the stock CT wheel just blowing hot air. 57trim upgrade would make that much power without breaking a sweat.
Enraged
21
Turbo Habanero;1761744 said:
350whp? or BHP?
like I said, my car did 320rwhp with room for more once the issues are sorted. that was at 14-15psi which tapers down to 9.5 at redline.
Turbo Habanero
4,229
Tucson,AZ
i guess there just might be some serious issues with my car then
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Probably with the support stuff that you NEED to get there without blowing something up, the cheapest and most reliable way to get to 350 WHP with the stock CT26 is to send it out for a 57 trim upgrade.
tomsupra8683
82gts7mgte
Mar 31, 2007
105
puyallup
Im going to upgrade too the 57trim soon as i have the money but ill dyno before and after.Im certain im around the 300hp mark.Ive have no choke of any sort in the top end infact i smoke tires in 3rd gear on the freeway and hit the rev limiter easy.
Enraged
21
many people have run stock CTs at 12-15 psi all day long. they are so cheap, it's almost a maintenance item if they die :)
but I agree with the other posters, upgraded to at least a 57 trim would make getting 350rwhp simpler
Kai
That Limey Bastard
Toyota aren't making CT26's anymore...the supply will run out someday...
