I have problem with my 1JZ. It seems like the ECU caps are bad, but nothing seems to help. Car works great when its cold, but after 10-15 minutes it starts running on 4 cyl and plugs 3 and 5 are soaked.
I made the test that is on SF.com where I plugged a bulb on nr 3 cylinders injetor plug. The bulb came on and wasnt flickering, on cyl 2 it was flickering like it should, so the injector is staying wide open.
So far I've tried:
-Changed ECU caps
-Changed ECU injector driver blocks
-Sprayed the ECU board with cold spray when the car is running
-New plugs
I havent tried:
-another ECU
Can it be something else other than the ECU that drives the injectors that is broken?
I have Mine's ECU coming to me from Japan, but it will take two to three weeks still and I'd like to keep this ECU as a backup, so I'd like to get it working.
Here's some pics I took from the ECU board:
Any help is grately appreciated.
Krister
So far I've tried:
-Changed ECU caps
-New plugs
I havent tried:
-another ECU
Krister
