2jzgte vvti swap
aveo900
8
california
Ok guys so my 7m is done with and well I wanna swap it :naughty: I want to know how to do it myself I have some mechanical experience and can some one explain how to turn an auto to manual an r154
Sly-0ne
19
Lowell,ma
aveo900;1927561 said:
What about the auto to manual swap ???
Is your toyota auto or manual?
To mate r154 with 2jz. Your going to need a 1jz bell housing.
Driftmotion has them around $300..?
Also, clutch set up, flywheel and driveshaft.
Driveshaft from turbo supra w/r154...
Supra800
12
Pa
Hey I have 90 supra mt car and I did the 2jzgte vvti swap and I keep hitting a false rev limiter around 4500, what wires for the ecu do I have to hook up to make the car drive? Please help
jesse_rc1991
169
austin
if its anything like the 2jzgte non vvti the you would ground the NSW and STA wires. Others have had this problem and doing this usually solves it for them. Look at Wilbo666 for your ecu pinout to find out which wires these are for your vvti
jesse_rc1991
169
austin
so I assume you grounded B2 pin #13, F59 pin # 26, and F59 pin#2 to a good ground. my next guess would be prolly power F59 17 which is D maybe it will tell you your in drive and work. also have some theorys with pin bf2 pin2 and bf3 pin3
Supra800
12
Pa
Can you guys tell me what wires shoulda bin hooked up the pin #s and all, act like I'm starting with an untouched harness that was extended
