2jzgte throttle cable
jza71
HELL
MN, USA
www.geocities.com
For all newbiez.....DO NOT GET THE 2jz-gte THROTLE CABLE!
2jz-gte cable will not fit perfectly. To make it fit, you'll have to move the bracket back 1 hole. 2jz-gte cable cost too much.
Camry and corolla cable will fit perfectly fine without moving the bracket. You'll have a small amount of slack. You could leave it as is or just zip tie the extra slack down to make it look pretty. It is free from your local junk yard or you can pay them $2 for it.
johnverheij
shoarmateam member
Nov 21, 2006
64
netherlands
Rich said:
Just go to your local toyo dealer and order a 2jzgte one, why the h*ll order one from across the ocean !?!?
i think that the cable from the local dealer
also comes from the other side of the ocean
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Troyota said:
I've got the Camry cable...how did you guys route or hold down your cable?!? I can't figure out what to do with the slack in order for it not to stick straight up in the air.
I stuck mine under the rear hook.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
this is for the 2jzgte not 1jzgte
jza71
HELL
MN, USA
www.geocities.com
SupraClaou said:
So , what is the correct cable for 2jzgte ?
In the mk3 body, it does not matter if it's a 2j or 1j engine. You will need the Camry or Corolla throtle cable. The 2jzgte cable will not fit correctly even if it is the 2jz engine.
SupraClaou
846
4
Athens,Greece
Camry or Corolla...Ok I got it!
Which do you recomend?Do they have the same price from Toyota?
tlo86
Jul 24, 2005
3,914
Colorado
i know at least 5 people that have said the mkiv throttle cable fits perfect when doing a 2jzgte aristo swap. including tissimo, suprastanger, crazysupra2jz all who have running cars and did not relocate a bracket or anything like you do for the 1jz
and supra claou best bet is a junkyard then goto toyota like its been said they are prolly 2$ from a junker car or free. if you dont have access they are prolly 40$ from a dealer
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
+1 here, I have a 1.5jz in a mkiii and use the mkiv throttle cable without relocating a bracket.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
I got mine for $10 from the junk yard, and I had to pull it.
