2JZGTE Swap
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
mk34lyf;990286 said:
Really, b/c I don't recall an answer for a pre-build 2JZ Mk3 Supra swap kit. I'll check again.
There isn't one. Never has been, probably never will be. If you're not ready to sit down and do some reading on the internet, you're not even close to prepared for swapping an engine into a vehicle it wasn't designed to fit into.
Oh yea, how much of a difference is there between the 2JZGTE and the 1JZGTE? Do they produce the same power as easily and cheaply? Are they both as reliable? How many liters is a stock 1JZGTE? Thanks and sorry for all the nooby questions.
If you're asking this question, you need to do more research into what motor is right for you.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Ok, the easiest way to do it (saying this again) is to order an aristo front cut, swap the oil pans to a rear/mid sump setup, send the wiring to Dr.Tweak and then go and put the pieces together. Transmission wise will depend on what tranny you use.
^he's so smart.............and patient..........and helpful.............now I really hate him.
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
why not let Dr Tweak do the whole thing and call it a day. He's done swaps for 1j, 2j, hell all kinds of toyo engines...
