2JZGTE swap ran but not anymore...
Jacob
the overkillist
Feb 11, 2007
196
East Coast USA
Little background... This is my first build and first time turning wrenches on my own. I had help over the phone on the wiring and I've gotten my car to crank and run here's my shitty but awesome to me crank vid...
After that it crank and idled fine. An oddity was the temp sensor always went thru the roof. I found the ground was no good so I grounded it. The temp went to normal. I took it out for a drive around the block (without boost connected. I didn't even make it back to the house when problems started. I just let off the gas it stumble to a death. It tried cranking it a few, finally did but really didn't seem like it was able to idle on it's own till I got going. Got back to the house, turn off went to work. When I came back it cranked first try and seemed to be just fine for 5 minutes. I turned it off. Came back to it tried to crank it and fawk!! It would fire some cylinders and die. I'd crank it with my foot on the gas and I'd catch the few cylinders firing and it'd rev on those but die out once I took my off the gas. Now (the past few days it won't even catch the 1-2 cylinders still goin poppup. I pulled codes ... 21 = O2 sensor sig, 22 = THW water temp signal, 31 air flow meter ....I used MK3 codes to translate. I replaced teh water temp sensor. I was told use a volt meter to check resistance on this and that and volts from the sensors ...I haven't cuz I fuckin just gave up the other day.
PLEASE HELP!!!! ...I am tired of not having a car!!!!!! I am stuck at my fuckin house on my day off. I fucking ran out of butter and it would be a 1 hr walk/trip to get more FUCK!!! I have been carless since I was 19.
MY CELL is 9547782099 ...PLEASE if you are compitent help.
Can you put up another video of what it's doing now? It might help figure the problems out.
Jacob
the overkillist
Feb 11, 2007
196
East Coast USA
Just got back from walking to the store for butter, cork screw, and the bigger bottle of Pinot Grigio.
I regrounded a few things. Friend told me that the water temp should be grounded to the intake. Another vid will come tomorrow. It just won't crank now ...not even a little missfire or anything. the starter just turns the motor. Speaking of thte battery is now low cuz of all the trying and no starting. By tomorrow, it may be on the flatbed to http://www.phoenixmotorsportsonline.com/ so it may not matter. I just can't take being carless... it's like my balls were cut off.
tissimo
Stock is boring :(
Melbourne, FL
the water temp sensor does NOT ground to the intake manifold. Its a closed circuit to the ecu only. That will throw a code and cause the car to run pretty funky. Code 31 is the map sensor iirc. Make sure the circuit for that is wired correctly. Thats like trying to run without the map sensor at all and it probably wont run, haha.
Jacob
the overkillist
Feb 11, 2007
196
East Coast USA
well, however much ground the temp to intake makes shit funky, it doesn't explain the shit I've been experiencing. I will double check the MAP wiring but it is flat beding if it doesn't pull a rabbit out its ass by 10am. I can't take being carless. It's seriously some kinda new mental disorder that i am pioneering.
Jacob
the overkillist
Feb 11, 2007
196
East Coast USA
dude, I started this project in december of 2006. I've got/own/possess an ass load of patience. BUT I need to have a car where I live and I don't want to have to buy another beater and leave my precious sit for another semester while assholes who never did/would/will lift a finger to help ask me over and over if the car is done yet. No sir, not impatient just want to drive the car that I've bled so much of every aspect of my life over. ...feel me bro?
SupraMario
I think it was the google
7
The Farm
Holy shit man! 2006 ??? fuck dude you should have come on here a long time ago, hell if I remember correctly aaron from DM flew all the way from cali to help Jay(suprahero) out with his 1jz. You own a supra = your family, and we will take care of you, so yea I feel you on that. Pheonixtuning and Dr. Tweak are great! You should have the car running asap if you do bring it to him. GL man, and I wish you the best.
tissimo
Stock is boring :(
Melbourne, FL
Spoon feeding people information gets very annoying, especially when they get pissy. The Ecu is telling you whats wrong, fix it. If you dont want to deal with it anymore and just want to drive it, send the work to a capable shop and pick it up later.
Jacob
the overkillist
Feb 11, 2007
196
East Coast USA
tissimo, sorry that post was 6 am today (up all night with a big bottle of wine) ...I don't think I was bitching at you but I can't remember. I think I was just tired, tipsy, and generally annoyed with everything including the fact that I stayed up till 6am. Apologies.
I think I am stuck between being fed up with it all and getting it done. Let me not post up till I make up my mind I guess. I don't need to pass on my frustration to you guys. I do appreciate the input. My friend read your post and realized he'd fucked up helping me out. I told it's ok, he's still been a huge help.
To me fixing what the ECU is throwing, I think my wiring is making the ECU throw codes. I'll have to go thru it again.
Apologies, to D34DC311. Didn't need to dump on you. You didn't know anyway. btw ...I don't have a supra ...it's a Cressida so may be I can still be a distant cousin though.
laters
edit: forgot to mention that I didn't even remember my post (#5), when I messaged you... sorry that did seem quite dickish.
EDIT: I just let Phoenix motorsports deal with it. They've had it for awhile now ...feels like it's been 4 weeks give or take some days. I wish they'd get er dun already, trying not to pester them though.
tissimo
Stock is boring :(
Melbourne, FL
Yea, double check the wiring. Use a mkiv EWD as the pins will be similar, but the wire colors will not. Just ohm out the Map sensor, o2 sensor and the water temp sensors wires in the harness and make sure there going where they're supposed to be going.
