Little background... This is my first build and first time turning wrenches on my own. I had help over the phone on the wiring and I've gotten my car to crank and run here's my shitty but awesome to me crank vid...
After that it crank and idled fine. An oddity was the temp sensor always went thru the roof. I found the ground was no good so I grounded it. The temp went to normal. I took it out for a drive around the block (without boost connected. I didn't even make it back to the house when problems started. I just let off the gas it stumble to a death. It tried cranking it a few, finally did but really didn't seem like it was able to idle on it's own till I got going. Got back to the house, turn off went to work. When I came back it cranked first try and seemed to be just fine for 5 minutes. I turned it off. Came back to it tried to crank it and fawk!! It would fire some cylinders and die. I'd crank it with my foot on the gas and I'd catch the few cylinders firing and it'd rev on those but die out once I took my off the gas. Now (the past few days it won't even catch the 1-2 cylinders still goin poppup. I pulled codes ... 21 = O2 sensor sig, 22 = THW water temp signal, 31 air flow meter ....I used MK3 codes to translate. I replaced teh water temp sensor. I was told use a volt meter to check resistance on this and that and volts from the sensors ...I haven't cuz I fuckin just gave up the other day.
PLEASE HELP!!!! ...I am tired of not having a car!!!!!! I am stuck at my fuckin house on my day off. I fucking ran out of butter and it would be a 1 hr walk/trip to get more FUCK!!! I have been carless since I was 19.
MY CELL is 9547782099 ...PLEASE if you are compitent help.
