2jzgte ac compressor in mk3
jesse_rc1991
169
austin
i have the aristo 2jzgte ac compressor with my 7mgte compressor head but when i go to slide the compressor on the long stud on the back side it hits the relief valve on the 7mgte head. did you guys encounter this problem? would i just remove the relief valve or remove the stud? dont really want to do the relief valve cause i dont my compressor to blow up.
I think i just used a bolt or installed the valve after the i put the line on. It was 1 of the 2.
jesse_rc1991
169
austin
yea i think a bolt would be better cause the stud is still goning to hit the relief valve after i take it off and try to bolt it on . thanks though and what part of the bracket do you need to grind again to clear the ac line?
You will see when you put it on.
Iirc you might not need to if you put the bracket on after the ac is together bit idk for sure.
jesse_rc1991
169
austin
hit another problem while trying to mock up the ac compressor and pump bracket
bracket would block the high side bolt
would the lines fit in the space between the head and bracket. haven't got my ac lines yet
Ive read your supposed to grind the bracket a bit but not sure where really
Iirc thats the general area you have to grind. Use bolts instead of studs and put the lines on first and then bolt on the ps bracket.
