I did the 2jzget swap on my 90 supra with 7m electonics ran into some little problem.
First it was throwing code 22 and 51. It will rev to 5000rpm fine but now i got code 22 coolant temp sensor fixed and it will pop and hesitate when i rev it to 1800-2000rpm. It will pop and hesitate but once it past that itll rev through the rest if the rpm fine. Its still throwing code 51, ac switch. Wideband reads real lean when it hits 1800-2200rpm. Wideband read 16-17 and it just shows blank after that. I Tried adding fuel to those rpm but no difference, still does the same thing. Setup is afc+vpc, 680cc, rewired 255 fp, is300 cop, new is300 wires, plugs gap to .28, gt40 turbo, ffim. Thanks in advanced.
