I am swapping a 2jzge engine into my 1990 supra. Both engines were NA.  I bought the power steering hig pressure hose from driftmotion and then saw that my  2jzge engine has a banjo bolt off the power steering pump and it has the two pronged vacuum switch.  If I use the high pressure hose from driftmotion I won't have the pronged vacuum switch.  Will that be a problem?
Thanks
Paul
			Thanks
Paul
