looked up some info on using a 2jzge rear sump oil pan on a aristo 2jzgte with a front sump and found that it will work but all you would have to do is drill and tap the turbo drain hole in the ge oil pan. my question is, is that really it because im looking into getting one from a sc300 with the pickup tube and baffle and such. so would this work and has anyone done this?
