2jzge NA-T bigger injector question
tegrab18
5
NY
I have a 2001 lexus gs300 and i have tried doing tons of research to find what injectors will fit. I have turned it into a NA-T and tring to go up a little in injector size. i heard that the RX-7 injectors will fit but upon looking at them the just dont look right. i want to stick with a semi small injector like 440-550 running high impedance so i dont need to incorporate a resistor pack. I was told the Supra TT injectors fit and i have a set and they totally dont. I was curious on what other vehicles will fit the rail and intake without modification. if anyone can help that would be awesome.
tegrab18
5
NY
tegrab18
5
NY
RockPaperSwoRD
I have aCustom User Title
Jul 26, 2008
392
SanAntonio
if you have a 2jz ge then your fuel rail is top feed and you use 14mm injectors(import type). injectors from a 7mgte should work. you should double check resistance though not sure if 7m uses high or low
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
TT injectors will not fit they are side feed and 14mm. Any standard 11mm Import injectors will work, for instance you can get a set of Precision 550 Injectors for a 7M-GTE and they will work(check to make sure they are high impedance as the stock 7M are low impedance).
Take a look at SRT's website as they specialize in 2JZ-GE stuff.
HTH,
Seth
tegrab18
5
NY
Thanks for the move on my thread wasnt sure exactly where to put this info. Also ive been noticing the 7MGTE are low impedance and mine is high. Thank you for all the info guys. big help. Also do you know if the RX-7 injectors are a drop in, or has anyone done it yet.
