2jzge dyno results 660whp @20psi
1986.5supra_kid
Rice? No its Corn (E85)
another 2jzge :)
id1000
aem v2
s366
lq9 coils
TT HG
ARP Studs
r154 MC and DM parts
ACT extreme PP and 6 puck
3in steel one piece 3.91
Flexfuel sensor
20psi on e85
16psi on 93octane
has A/c and soon to have cruise control
this is a daily driver
The motor is from a 1992 sc300 and the motor has roughly 200k total miles on it now counting the rebuild 40k ago which was seal and bearings no machine work done.
Borgs put out great numbers. Lbc guy made 774 2jzgte built withy small twin efr turbos in vegas. Anoth made 476 1.5jz with a big efr turbo at 14 psi.
Those are nice numbers.
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
mk3 salty;2024800 said:
What RPM do you hit full boost?
looking at the dyno grap it looks like 5000-5500rpm it hits real hard. im sorta in the same boat as suprakid where i maxed out my hx35 and want more but love the crazy bottom end power. seeing his graph makes me positive now that im going with the fmw s362. flows a lot more than the hx35 but hits hard a 4000rpm from what ive seen. the s366 is more of a hw and drag turbo. wouldn't be good for autox or small tracks. but the numbers are impressive for the boost levels no doubt!
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
Borgs generally do better than their counterparts, thats for sure.. the 66 also has nowhere neat the heatsoak that the HX would have had either.
Great numbers. GL
I just got home from the dyno ten minutes ago and I see this...............UGHHHHH!!!!!
My car only made 550rwhp @ 23psi and 501 rwtq. The only print out the guy gave me was my last run though. It shows 538 and 497 max torque at 4650rpm. The car was hot since we did about four pulls back to back. I'm running 93 octane with 50/50 methanol injection. I was hoping to see better numbers but it didn't happen. It's probably because of my timing but I'm not sure about that either. I used to run more timing than I do now and my car loved it. For some reason though, I've backed it down some for a more conservative tune. 550 horsepower will handle most of the cars I run up on here in the good ol south. Not a lot of exotic cars or supras around here. Mainly just mustangs and Camaros.
I would love to talk with you about your tune if you get a chance so I can compare your timing numbers with mine just for reference. Thanks, Jay
Congrats on the great numbers.
