Car:
1987 Supra
Stock Aristo 2JZ mated to a R154
2.5" intake pipe with DM FMIC
3" Exhaust with a 50mm restrictor plate
The problem I'm dealing with is that the turbos won't push past 4.5~5 psi of pressure. The engine will turn all the way to redline without a problem, abit with a lack of power, but it's smooth all the way. There are no codes. And I get a little dip in the pressure at around 3800 rpm. Then it's right back to 4.5 psi.
I have checked all the piping and tightened all the T-clamps. I don't believe there is a boost leak in the intake piping. I have also disconnected the wastgate vacuum line to see if there would be any change, there wasn't.
The restrictor plate is used to control the boost since the JDM wastgate is to small. But 50mm -52mm seems to be the standard that people use to see 16 psi. I would be surprised if my restrictor plate was keeping it down at 5psi. I'm going to enlarge it this weekend to see if there is any change. But I would like to see if anybody else has any ideas before I do. Also the exhaust 3" mandrel all the way back to a straight through muffler. If this doesn't have an effect I'm going to do a temp TTC mod for further diagnosis.
One oddity I noticed is if I do a 4th to 2nd down shift with a rev match at anywhere above 3400 rpm the boost falls off to 0psi after a couple hundred RPM. If I let the clutch bring the revs up to that range then the boost stays at 5psi.
Any ideas?
1987 Supra
Any ideas?
