2JZ wiring hook up to coil packs
bfairris123
4
Trinidad &tobago
Experiencing miss firing on the middle coil pack.
Sent from my SM-J320M using Tapatalk
And what are you looking for?
2jz is sequential ignition wiring. Coils are all individual and fire indivdually of each other.
If it’s during boost then pull the blue boots off me check for crack. Epoxy over the cracks and head shrink the shaft. Or replace with new.
pwpanas
Duluth, GA
Inspect your coil pack connectors. They're fare more likely to be brittle and cracked than the spark plug boot, and can definitely be the cause of a misfire.
bfairris123
4
Trinidad &tobago
Thanks for the assistance, I got through with the miss firing but I would like to know the gapping on the spark plugs because I need to change spark plugs also
bfairris123
4
Trinidad &tobago
Hey man thank for your input on Saturday change plugs gap plugs at 0.28mm when I started vehicle sounds beautiful but when running reach 170km I got some resistance
Kinder like hold back so I went today
to put back some music in the ride on reaching home I decided to gap the plugs at 0.35 to get a better ride over 170km but at low speed work well no missing thank
