On my 2J, there are 3 water line outlets that I am having a problem staying plugged. I have been using the rubber hose plugs to go over the line openings but with the pressure and heat they are quickly drying out and getting pin holes that leak BAD. I am wondering if I cut the line fittings down tothe actual line, could I use something like JB Weld to seal that line up?
