I am using a 1jz harness and 1jz ecu to run my 2jz-gte. SupraNick ran this same set up for years and was successful, and I believe that I will be successful as well. However, if/when I were to upgrade to a single, I am going to need to run some sort of tuning or engine management to get everything running right. Just wondering what you're using and why. I know that standalone is probably best, but what are the other set ups out there?
