2JZ Motor Idling Bad, Shuts Off... Need some feedback!
GeneStarWindGSW
Been To The Other Side...
Mar 25, 2007
992
No Man's Land
www.bidmingle.com
Alright guys, i got an update on this =). My friend got it to idle alot better by capping off alot of the vacuum lines that i didn't need since they were affilated with the EGR. Now it idles at about 900 rpms, so i think its starting to be alot happier now :D. Now all im left to do is just put the throttle cable bracket back on. I do need new front tires.
Also theres another problem, My brake pedal gets stuck when we bolt down the the master brake cylinder part down to my brake booster. Im not sure what to do about since its very important for my brakes to work. The brake pedal works when we loosen off the master brake cylinder but once it start to bolt it back down it just gets the pedal stuck. :dunno: what to do about that
OneJoeZee
Retired Post Whore
aboard the Argama
All that stuff you removed that you have no idea what it does... Put it back. If you don't know what it is, why did you remove it?
How do you know you don't need it if you don't even know what it is?
GeneStarWindGSW
Mar 25, 2007
992
No Man's Land
www.bidmingle.com
Well i've found out that the things that were removed are all affilated with the EGR, so its not important that they go back on and they weren't even connected to begin with.. so -_-. I'll give another look at this tomorrow
*Edit*
haven't checked for codes but the check engine light has never came on except for once and that was when it was driven.
daneyan
441
South Florida
that's what i was told by patrick and joseph so we'll see i'll let u know if i got the date wrong or something could be the 22nd i might be mistaken
