I purchased a 2jzgte with w58, wiring, ecu and all sensors. I needed help with wiring the 2jz ecu to the car. Btw I am going to upgrade to the r154 and need good sites to buy bell housing and flywheel and other things for this swap.
Nomad707;1193059 said:i have the JZ bellhousing if you want to buy it. g/l with the swap =)
Highnitro;1193902 said:the automatic wiring harness will work, u might have to jump the neutral start switch but its not a problem at all. if you want to post pics go to a site like http://www.photobucket.com and host them there, then u can post them up here.
