2JZ/MK3/8.8 8 sec street car build.
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Going for mk3 record. street car/ IRS . car will be repainted and tastefully modded .
Have a build thread on SF but I haven't been here in quite some time so figured id share my build.
1990 NA
Dirty bay
Clean bay
Need to room for tires
Cut instead of roll, much better
ARP wheel studs in place
Time to fab the 8.8 in
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Subframe stripped, getting braced then off to powdercoating
old crash bar gone, chromoly in its place
Time to cut the rear floor and custom make a cell and battery mount.
Parts coming in
Custom Naber Racing pistons
Intake
Seats
More to come
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Got bored, made my new jump post !
Intake is setup and ready with FID2000s
Rear end is coming a long ways. the rear mounts are tacd in position, now to chop and chromoly the front side
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
rear end fab is pretty much done , tomorrow it will be dropped off for blasting and powdercoating.
Making the front mount more rigid
Parts showing up for the diff build.
Strange 31 spline spool
Changed up the design on the piston and decided to go a different route. Custom Naber Racing spec piston will be getting used (the one on the left) :)
Finishing up the rear fuel setup in the next couple days
-Saif
Very impressive welds and it's going to be a cool project to keep up with. Thanks for sharing.
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
SupraClaou;2087642 said:
Nice... Very interested! Monster street mk3 for sure.
What transmission you'll use? And what's the ratio on the 8.8 diff?
Full billet / t brake FTI TH400/ 3.55 richmond gear
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Ronnie K bushings came in (honestly not impressed with them at all , specially after so many people recommended them)
Subframe powder coated, bushings installed ( currently in process of making my own but will install after Tx2k, these will do for now)
all suspension parts powdercoated and new Energy bushings installed throughout the whole rear.
Knuckles are out and I will be pressing in new wheel bearings while out, might as well do it
Ring and pinion came in , no pic yet but once the rebuild kit comes in and the cover ill be building the diff.
Piratetip
Far From Maddening Crowds
1,179
70
MKE, WI
Whats your opinion on the bushings?
I am taking an alternative path with mine, curious what your take is.
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
quality is just not what i expected. those are pour in poly. un even and not consistent at all. both halfs dont line up as you can see with the metal sleeves in. the sleevs them selves just very poor machinning/drilling and not to mention all the hats on the bushings look like they were cut out using a hand blade and not a lathe like i expected. numerous craters and sponge like texture.
Granted they still fit good and im sure they will perform good as well but for approx 300$ the quality doe not match the price. im in the process of making some myself so ill be swapping mine in once im done
Piratetip
1,179
70
MKE, WI
Gotcha.
I am also in the process of making my own set of molds :D
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
Custom Naber Racing Titanium intake and exhaust valves +1mm on both.
stock intake weights in at hefty 49 grams new titaniuems weight it at only 30 grams
while stock exhaust weights in at 44 grams and the new titanium weight in at just 27 grams!!!
less spring pressure/ more control at 50* angled valves = sex
