Ok, before most of you spazz out. Ive done a lot of research before asking. I realize the usdm 2jz injectors are 550cc and need a resistor pack......im intersted in the jdm 440cc injectors. I know the clips are the same and they both pop right in using the same fuel rail as well.....The problem im having is after the 440cc injectors are in, do i have to tune the car to achieve the hp gain? Or can i increase the air flow (upgrade intercooler pipinp)? Or can i use the 2jz map sensor? Thanks again
