2JZ-GTE Oil pan
Shadow
87 1JZ-GTE Single Turbo
May 25, 2005
304
Windsor, Ct
Is the oil pan from a 2JZ-GTE the same as the one from a 1JZ-GTE? Are they compatable? Will I be able to use a 2JZ-GTE oil pan on my 1JZ-GTE? Size difference? Any cross member clearance issues? Thanks.
rakkasan
Currahee!!
Fort Campbell, KY
suprastanger507mgte said:
He is right....just in case you needed a 2nd opinion :)
Well, as long as it's a mid sump I'll agree. The front sumps from the aristos will fit the motor, but not MKIII's...
Technicalities....:icon_bigg
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
You are right...I just gave a generic answer to a generic question :)
BTW: A sump from a Lexus sc300 2jz will work - just need to drill the holes out for the oil retun...its already stamped.
Shadow
May 25, 2005
304
Windsor, Ct
Oh really! Toyota has an oil pan for a Toyota motor? That's crazy! I thought I'd be able to pick one up at KIA. Just joking guys! :biglaugh: I should have been a bit more clear. I should have asked if anyone had a spair one laying around for sale or if there was anywhere that was selling an aftermarket one.
crazysupra2JZ
740
Georgia
here's everything you need. it's a 2jz-gte oil pan. i guess the oil pick up will work.
Shadow
May 25, 2005
304
Windsor, Ct
So if I were to go to Toyota and pick up the lower oil pan from a 2JZ-GE from a Supra, then it will fit on my 1JZ-GTE and fit into my mkIII Supra? And it will be cheaper then the lower pan from a 2JZ-GTE?
