So, I am getting around to putting the motor back together. Put in ARP bolts and studs, new head gasket, the 2jz cams I bought from someone on here that they were running in their 1jz, and cam seals.
Here is my dilemma. I'm not sure if anyone else has this issue, or maybe this is acceptable. The 2jzgte tsrm says the .30 is the maximum the thrust bearing should be out.
Check this out:
There is no wiggle room for the cams to go back at all.
Thanks in advance...
Check this out:
