Hi - I'm in England and replacing my 7M-GE with a 2JZ-GE from a Mk4 Supra
So as the Mk4 uses a W58 I'm keeping my gearbox, and obtained a Mk4 Bellhousing.
It looks like N/A Clutches are the same on the Mk3 and Mk4 . . . . but I wonder if anyone can tell me if the FLYWHEEL from my 7M-GE will fit on the 2JZ-GE?
And also whether the Clutch Fork and Clutch Slave Cylinder (from my 7M-GE) will fit? They both look very similar, but different part numbers.
Hope somebody can help
(I have tried searching on here . . . but most of the info relates to the Turbo engines, which have different clutch setups . . . and usually different gearboxes)
