2JZ Fuel Injectors
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I trashed the only clips I had (wires on them were probably too short anyways). I'm sure there are MANY people on here that would love to help you out with clips tho... just ask around.
yea, I trashed 90% of the 2JZGE stuff. Including the metal vac. lines.
If I were you I'd hook up that valve just like it came off... It's not associated with the EGR.
off topic:
How did you do the EGR delete? block off the port on head and block off the port on the TB? and block off any vac. lines leading there? (thats the right way at least.. that or just leave it alone ;))
GeneStarWindGSW
Been To The Other Side...
Mar 25, 2007
992
No Man's Land
www.bidmingle.com
yea im just looking for some clips now. im going to run the 2jz injectors for a minute since i haven't cranked the car up in months. just wanna give it back some life :p.
yea i put the block offs on the head side and on the TB side. Now im trying to find what vac lines are associated with the EGR so i can cap them, i just don't know which ones are.
do you really need those metal vac lines?
Also i just checked the impemdence on those 7M-GE injectors and they are low impedecence (3 Ohms). Thats the ones with the yellow cliped side. I guess i need the green ones then?
i also found this
http://www.lextreme.com/injectors.html
