Your absolutely right, but the GE fan can still be used. Yes gentlemen you can use it, you just have to use two washers per stud on the clutch and it spaces out perfectly with no unbalanced issues because the washers are evenly spaced and all weigh the same. I just confirmed it. It comes not awful close or anything to the water neck, it has ample spacing.
