Hi, I was just wondering if theres anything wrong in these pictures? Thanks (Mainly BOV and other hoses/lines)
chopstickz;933918 said:so can this be an easy fix?
jza71;933964 said:So are are you guys saying that the stock BOV is in the wrong place too?
JASONA70;934050 said:
synco357;936967 said:Blow off valve will be protecting the primary turbo from surging. However, the secondary turbo doesn`t have anything protecting it. Secondary turbo need a BOV in its` charge pipe. Failing that just place the valve before the throttle body!
DegreE;937191 said:Shouldn't it be recirculated back into the system instead of vented into the atmosphere?
