2jz cut crank?
j3r3my
240
mass
Ok I can't find a definitive answer but I'm rebuilding a 2j that spun a bearing..now I'm being told conflicting story's..some are saying 2jz cranks are NOT good to have cut! But others are saying its fine.. Does anyone know 100%?? If I can cut this one that's be awsome or if not ill use it as a boat anchor
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
It can be cut without issue, but with used 2JZ cranks being relatively plentiful, I would probably get a different crank if it was mine. No sense losing material when a good one can be had relatively cheaply.
Jeff
