hvyman;2017765 said:
No. It's just the next size in bearings. It's like that for every motor. Std 10 20.
Can't make the next size too small as your already talking about a small amount.
Your over thinking it a bit it seems like.
Appreciate you help, but I'm still not clear on one thing.
If my crank has been ground to accept 0.01" (0.25mm) larger than stock bearings, what diameter should my crank journals be?
The bearings that came out of the crank do have 0.25 stamped on them - but I'm curious as to what diameter my crank should be?
I mean, it'll be 0.25mm thinner than the STD size, but what is the STD size?
If you can buy STD, 0.01 and 0.02 sized bearings, those sizes must reference a base measurement.
