2JZ Auto To Manual List
GeneStarWindGSW
Been To The Other Side...
Mar 25, 2007
992
No Man's Land
www.bidmingle.com
Ok i want to do the conversion from auto to stick but i need to know all the parts i would need down to last detail just in case of anything because im not sure of everything i need only some parts. I know we have some talented individuals here who can help me out :icon_bigg
P.S - The parts list im trying to make are for an R154 so correct me on anything if im wrong.
GeneStarWindGSW
Mar 25, 2007
992
No Man's Land
www.bidmingle.com
See if im right about this im not sure.
  • Manual R154 5spd tranny
  • 5spd drive shaft (get u-joints replaced N make sure to align it properly)
  • 5spd 1JZ flywheel**
  • 5spd 1JZ flywheel & bolts**
  • pilot bearing (for flywheel)
  • rear transmission seal!
  • rear main engine seal!
  • throw out bearing
  • two hydraulic lines
  • lower and two side covers plates for tranny bell housing
  • slave cylinder
  • hardpipe
  • clutch pedal assembly
  • 5spd brake pedal assembly
  • shifter (make sure all the rubber covers included)
  • shifter boot ( with lower metal frame ?)
  • rubber cover for bottom of shifter
  • 5spd ECU (Auto ECU Works)
  • master cylinder
  • trans crossmember
  • clutch release fork and pin
  • clutch
  • clutch hub and snap rings
  • clutch disk
  • clutch plate
  • driver side? engine-trans "wing" bracket
  • shifter bushings
  • lower trans inspection cover
this is what i've come up with so far.
correct me if i'm wrong on anything, posted a part wrong or name , or double posted a part or something. Also if you can give Part Numbers that would be nice. thanks =).
my resources
Link #1
Link #2
Link #2
**Corrections
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i think you'll need 1jz bellhousing. as well as a 1jz flywheel. or what someone wrote as 'order a 7m flywheel and have 2j pattern drilled into it'. someone correct me if im wrong :):)
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
yup, 1JZ Bellhousing for R154 (I got mine from Jay @ Champion Toyota), 1JZ Flywheel for R154
the rest will be the same as if you were doing an auto to 5spd conversion in an 7MGTE MKIII.
c_ronius is right, your auto ECU will work fine.
Satan
Tampa
Is the pilot bearing for the 2JZ, same as the 7M?
I have 2 of 'em on hand for mating the tranny up today, but the dealer's parts counter is closed. Just hoping someone can verify before I get started later today.
E
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Apparently this isn't correct. I thought I remembered reading it working but I was corrected in another thread. My apologies.
tlo86
Jul 24, 2005
3,914
Colorado
same here Lol. old thread ;) if anyone is interested though i have a list of what to buy im my build thread :) somewhere....
