2JZ at local junkyard....
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
I was doin some lookin around at my local junkyard and see a 97 Soarer hit from behind with a 2JZGE.... My question is can i use any of these parts on my 1J???
Im going to get the Throttle cable, and power steering hose... Anything else???
Also how do you remove the throttle cable??? It looks like it is Stuck!!!
OneJoeZee
Retired Post Whore
aboard the Argama
What good is the throttle cable to you? The GTE cable from a MKIv(front facing intake) is the one you want. Unless sombody knows something I dont know about the NA cable.(7M style intake).
Ken
350
Houston, TX
see if there are any '92-'96 4 cylinder camrys around and get the throttle cable from that.
Other than that, really nothing you can use other than the block if you decide to go 1.5jz.
Satan
Tampa
Things you can use are listed in a sticky on SF, but there's not too many things you can use... motor mounts (not the brackets), oil pan (modify to work), TPS, CPS, knock sensors.. I guess most of the sensors.
Oil filter bracket has plugs in the top, which can be used for a 7M oil pressure sender.
Not much else I can think of...
RacerXJ220
Interdimensional
Abalama
MKIV TT throttle cable sucks (but will work with modification). It's not bolt on bam it works.
Get the Camry one.
RacerXJ220
Interdimensional
Abalama
I had to move the throttle bracket back to the last hole on the manifold. It works, but it's not OEM quality stuff.
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Wow... I guess i wasnt so lucky!!!
Yah i feel stupid about the throttle cable:nono:...
A Camry cable works???
But will the power steering line work???
How about break rotors??? They look a little bigger...
Ken
350
Houston, TX
Yes, a Camry cable will work 100% and you will not have to move the throttle cable bracket back. Looks OEM too.
PS line, i have no clue. I assume it would be the same as the MK4, which is the line that mostly everyone uses for a JZ swap. Either way, just get it, if it doesn't work then you lost like what, 5 bucks? Just make sure it's in good condition.
