I found a great deal on some 225-55-16's for the sawblades I have on right now. What is the physical difference between those and the 225-50-16's I have on it now.
the second number is the ratio to the first number (tire width). so the new tires will be 55% of the width, whereas the stock tires are 50% width. did i do that right, or was i misinformed?
225 is the width
50/55 is the ratio of the width that is the height.
Your speedo will be off (traveling 62.1mph when your speedo reads 60)
You will gain 1/2" in height
While this is up can I change direction just a bit and ask if anyone has mounted 15" rims on a MA70? Will they clear the brakes?
I only ask cuz I have an almost brand new set of 255/50ZR15 Bfg Comp T/As that have just been sittin. It may look funny but they should stick in some corners too.
