2 quick questions
Back2Basics
Regular
Dec 30, 2005
317
Milwaukee, WI
1. can i use regular goodyear heater hose for my oil filter relocation hose? or do you need a special kind of oil protectant hose?
2. can i bridge a hose from the breather caps on each valve cover and then cap off the nipples on the accordian hose and throttle body? if the answer should be obvious or if im completely misunderstanding the pvc system let me know. im putting hardpipes in and just want it clean and simple up there without all the pipes/hoses.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
1: you need oil rated hose, otherwise it'll swell and get all soft. Coolant hose is just not compatible at all with oil.
2: you're serious? you are completely misunderstanding the PCV system. do yourself a favor and search the topic.
