2 issues:Vibration between shits, and slight oil/metalic smell after throttle let of
Supra0089
367
New Hampshire
This originally was posted in the General Discussion Forum, but it has basically been bumped onto the 2nd page with no reply, so I figured I might have posted it in the wrong section. Here we go:
Hey everyone. I had two issues show up almost at the same time, so they might be related.
I have an auto tranny, mk3, 550's, lex, walbro, fpr, 50 trim, running 16 psi with supporting mods.
Auto tranny shims 1/2, 2/3 accumulaters, 12x12 tranny oil cooler with fan
Issue 1: From first into 2nd gear, i feel a consistent vibration (2 to 3 vibrations) slight, as the car shifts from first to second. Once in gear, it immediately goes away. It is not present under WOT in any gear, just in the shifting 1/2 gear.
It happens under 13 psi (boost controller off), and at 16 psi.
Issue 2: On release of any moderate to heavy throttle, I smell a faint oil/metallic smell as I'm driving. This is happening recently. A buddy said that it could be the PCV.
Any feedback or leads are welcome here.
My build thread/mod list can be found here if anyone is interested further: http://www.supramania.com/forums/showthread.php?t=98571
Thanks in advance.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,253
55
Atlanta
Umm....What kind of vibrations are you getting between shits? :momaru:
What kind of toilet are you chillin on?
As for the metallic/oil smell...what have you been eating?
:rofl:
Ok- as for the vibration between shiFts,
I might guess either an issue with the flexplate/ bolts, or the torque converter.
Supra0089
367
New Hampshire
haha, woops...sorry about the that shi*t
Thanks for the advice on the torque converter. That's the second time that's been mentioned to me. Any other ideas are welcome.
The metallic/oil smell is after any moderate to heavy throttle is released from the motor (let off the gas). I am not loosing any oil or other liquids. I check them religiously. Again, my techy friends are saying PCV/blowby. Should I just get a catch can and see if that solves the issue?
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
I was getting that sort of metallic oil smell too and didn't think anything of it. Maybe a bad seal in the turbo. It turned out to be the head gasket area between cylinder 1 and 2 blew out. (2.0mm greddy mhg and arp studs)
supraguy@aol
Well-Known Member
Dec 30, 2005
4,253
55
Atlanta
When I get on moderate throttle, I sometimes smell oil too.
I think I have a slight leak from the oil feed on my turbo, and it's hitting my DP.
But not sure. Going to tear into it when I get home.
jucciz
Kuopio
maybe transmission is leaking oil to your exhaust?
does it smell transmission oil or normal motor oil?
