well i have had balencering and lightening work done to my 7m engine i feel i can spin it out to `12k,, at redline she is just as heatly sounding at 5k, or even 3k,
my friends say my car sounds like a street bike when coming down the street and powering through the gears.
while i have i have 1.5 pounds shaved off the crank and knifed edged, also running a aluminum flywheel,
the crank and rotating has been balenced 3 ytimes by two different shops,
dohc set up can usualy rev out well, but the shim over bucket set up usualay limits the rpm you can rev two, switching to shim under bucket or shimless buckets you can spin up further
for the 7m most of the limits are havin the stock turbo cause it runs out of breath around 5500rpm.
well the best engine options for the ma70 is a 2jz or a built 7m
mhg, rebuilt bottome end and a machined head and block deck.
