1UZ into MKIII
SupraPieces
157
New Jersey
www.facebook.com
Hey guys, I currently have an 87 na with a w58... I am trying.to determine what exactly is needed to swap in a 1UZ... As far as I can tell would be mounts, an adapted harness, and a bellhousing adapter and a flywheel. If I'm missing anything please tell me... my clutch is great so I won't need that... what flywheel works? I heard rumor that an ae86 flywheel would work but I have no hard evidence ... any help would be appreciated
Chambers
Now you know
Sep 9, 2007
983
Baltimore County, Maryland
This is what I can think of off hand:
1UZ-FE engine
Trans adapter plate
1UZ-FE bell housing
Flywheel (consider the complete kit 4U2QUK offers)
Swap mounts (consider the ones 4U2QUK offers)
Bolts for the trans adapter plate
Adapters for the power steering
A smaller brake booster (I use one from a mid 80's Toyota truck, the dia is still to big but its depth is good)
Radiator hoses from the SC
Heater core hoses from both the SC and Supra
Electric fans mounted to the rad, LS mechanical fan hub (no mech fan or clutch on it) if you dont plan on running a hydro fan set up
Adapters for the fuel lines
New clutch master cylinder
Quarter Master (style) throwout bearing/ clutch slave cylinder
Clutch lines
Pilot bearing
Flywheel bolts (I use 1JZ-GTE ARP bolts at 68 ft-lbs)
Pressure plate bolts
Valve cover gaskets and tube seals (if needed)
Re-seal oil pan (FIPG)
Check rear main seal (replace if oily)
Tune up:
- Timing Belt Kit (I use the Gatorback kit)
- NGK spark plug wires
- NGK spark plugs
- Caps and rotors (I use BOSCH)
