Satan;1922327 said:I've been using 2JZ N/A blocks with the 2JZ-TT pistons. Dunno how that works "compression-wise" in a 1J, 'cept that you would have to use 1J rods for sure (stroke length or whatnot).
AquaX;1922471 said:Wouldn't the pistons not reach tdc if i used 1jz rods... I know its probably wiser to use 2jzgte pistons but I dont want to spend money on them . I will be doing this in the spring and I will post the results! If anyone has a set of 2jzgte pistons and rods for sale let me know via PM.
525gte;1922517 said:I don't think you can use the 2j rods. In a 1j block. The 2j block is an inch taller. And the stroke is way to long for the 1j block.
You have to use 1j rods. And 2j gte pistons. Like hvyman
AquaX;1922525 said:The title of my thread is 1jzgte pistons in a 2jz block...
Ill be god dammed it is . i read it and my brain did not .. I seen 2j piston into a 1j block.AquaX;1922525 said:The title of my thread is 1jzgte pistons in a 2jz block...
