So I have a 1jzgte in a mk3 it has a 3inch exhaust boost cut controller apexi neo and a front mount and I've had this miss fire issue for a while now my car runs really rich like 10s at idle and wont rev past 4-5k when accelerating and wont boost past 10psi. Im pretty sure its ignition related i have 2 ecus one from a working car as I was told ive swapped ignitors bought brand new coil packs replaced one cam sensor and found a cracked wire on my rear cam sensor which ima waiting to replace when it gets here. My question is, Shouldnt I be throwing a check engine code if its a sensor or if the ecu isnt recieving a signal from my cam sensor it should throw one. I also disconnected both cam sensors while it was running and the idle didnt change at all still was miss firing any help is much needed thannks...
